qwertyv_134157
Oct 01, 2013AD + Token on Edge Client
We have implemented AD + RSA Token Authentication for a client. All is good on a browser because I can define as many input fields as I like (in this case 3 input fields). However, edge client (Android/IOS) seemed to be limited to 2 input fields only. Is it true? Or how can I pull out the 3rd input field.
Thanks in adv!
- Kevin_Stewart
Employee
A fairly common implementation is to have the user put the password and RSA token into the password field and then split them into separate variables on submission. Otherwise you could use the Web Logon option.
