Active Sync and OWA CAS servers load balaning
Hello All
I am having an LTM running an Ver 10.2.1 , we have one Virtual server for both Active Sync and OWA access, The pool have 5 servers in total lisening on port 443.
Persistence - cookie Load balancing - Least connection (member)
The pool member stats are bit odd
Server 1 and Server 3 are having very low current connection i.e 200 - 300 connection
Where as the other servers has 1.5K - 1.8K
Please could some one provide some ideas to get the load balaning more effective
- Joe_Francis
oops i have couple typos
- NikhilB
Employee
Use Least sessions LB algo and please let us know what you see.
- Joe_Francis
Thanks Nikhil
But I found a doc stating "Note: The Least Sessions methods are incompatible with cookie persistence." We use Cookie persistence
- NikhilB
Employee
apologies, didnt realize you were using cookie persistence. Have you tried the default round robin and checked the results? https://support.f5.com/kb/en-us/products/big-ip_ltm/manuals/product/ltm-implementations-11-2-0/19.html?sr=43357999
- Joe_Francis
No worries!
We have tried round robin before
- Joe_Francis
Please can I get an input on the above issue i am seeing
- NikhilB
Employee
Do you have snat configured? Assuming you also have one connect on? Have yo tried disabling persistence and seeing the results?`
- Joe_Francis
Yes we do have snat configure , no Oneconnect profile.
I havent tried removing the Cookie persistance - we are using an HTTP insert Cookie and Session cookie is CHECKED
