Kyungchan_Tae_3's avatar
Kyungchan_Tae_3
Dec 06, 2017
Active Connection clear time after node down
Hi All,
I have a question.
There are two Pool members in a one virtual server.
nPath configuration and use Performance L4.
Idle time of FastL4 profile is 300 seconds.
One node is down, but the active connection is not cleared after 300 seconds.
I experienced a Active connection clear after about 400 seconds.
I want to know why. Does this relate to the options below?
  1. Fast L4 Profile -> Reset on Timeout(Disable)
  2. Pools -> Action On Service Down(None)
Thanks.
