Active - Standby Sync using TMSH commands
Hi all,
I included around 60 LTMs in HPNA due to some bugs in Enterprise Manager.
I updated SNMP strings using tmsh commands to all active LTMs. I need the command for sync the devices manually.
Please do the needful.
- What_Lies_Bene1
Hey. The command to do the sync is:
. The command to display status istmsh run cm config-sync (to-group | from-group) 'device-group-name'
.tmsh show cm sync-status - StephanManthey
Nacreous
I just deleted my previous response. It was simply wrong.
In case all your devices belong to a SYNC-FAILOVER device group (i.e. 'device-group-failover'), you can synchronize them from CLI with the following command:tmsh run cm config-sync to-group device-group device-group-failoverPerhaps your SYNC-FAILOVER device group got a different name. You can check it as follows:
tmsh list cm device-group one-line | grep 'sync-failover' | awk '{print $3}'By putting the command above in backticks you can combine it with the sync command in a single line:
tmsh run cm config-sync to-group `tmsh list cm device-group one-line | grep 'sync-failover' | awk '{print $3}'` - StephanManthey
Nacreous
Hi Mareeswaran, there is a good article on the subject on AskF5. Please see SOL7024 for details.
The concept of device clustering changed completely with the introduction of v11 to become more flexible and scalable. The previous deployment was limited to 2 units only. Always make sure your units are synched with NTP:watch -d "ntpq -p"Sometimes a timestamp mismatch prevents a config sync. Failing SCCP communication may also impact the config sync operation on the previous H/W platforms, if I remember right.
Please keep in mind, that a "full_box_reboot" is required to restart the SCCP as well. Maybe some units (and SCCP) have a longer uptime than 497 days. Thanks, Stephan
