anujl_5566
Nov 07, 2011access rule for specific urls using Data group list
I wanted to give access to certain url's IF clients come from specific pool of IP's. I looked at devcentral and using the tips I found I wrote this url and it is working. Thought of sharing,
if { [matchclass [string tolower [HTTP::path]] equals $::send_verify_pin_urls] } {
if { not [matchclass [IP::client_addr] equals $::SEND_VERIFY_ALLOWED_IPs] } {
HTTP::respond 200 content "Not AllowedYou are not allowed to access this site!"
else {
log local0. "Life is good"
if { [matchclass [string tolower [HTTP::path]] equals $::IVR_urls] } {
if { not [matchclass [IP::client_addr] equals $::IVR_API_IPs ] } {
else {
- hoolio
Nice work. A few notes:
If you're on 9.4.4+ you should remove the $:: prefix from the datagroup name in the iRule.
If you're on 10+ you could replace matchclass with the class match command.
You could also consider performing the client IP lookup in the CLIENT_ACCEPTED event so you only do the lookup once per client connection instead of every HTTP request.
Aaron
