Noppadon_Panyar's avatar
Noppadon_Panyar
Jan 19, 2007
404 error during 5mins monitoring gap
i having the problem with 404 error response from server during the 5 miniutes monitoring gap.
How can i re-load balance the request to other nodes in the same pool?
I've searched in the forum and found some rule that talked about http redirection but it's not exactly what i want.
Here's is a rule that i defined:
   if { [string tolower [HTTP::host]] equals "www.abc.com" }
        { log "go to [HTTP::host]"
          if {[HTTP::uri] contains "secure"
         { HTTP::redirect https://[getfield [HTTP::host] ":" 1][HTTP::uri]
         log "client [IP::client_addr] redirected to: https://[getfield [HTTP::host] ":" 1][HTTP::uri]"
            else {
               pool abc_pool
   if { [string tolower [HTTP::host]] equals "www.test1.com"}
      pool test1_pool}
   if { [string tolower [HTTP::host]] equals "www.test2.com"}
      pool test2_pool}
   if { [string tolower [HTTP::host]] equals "www.test3.com"}
      pool test3_pool}
   if { [string tolower [HTTP::host]] equals "wap.abc.com"}
      pool wap_abc_pool}
when LB_FAILED {
      persist none
when HTTP_RESPONSE {
      if { [HTTP::status] contains "500" or [HTTP::status] contains "404"}
       HTTP::redirect http://[getfield [HTTP::host] ":" 1]
thanks in advance for any suggestions.
North
  • Colin_Walker_12's avatar
    Colin_Walker_12
    Historic F5 Account
    The command to re-load balance a connection is LB::reselect, but you'll likely need to use LB::detach first, since the BIG-IP will have already connected to the server. There are a few decent examples of this in the forums if you search, and a good example in the Wiki as well here Click here
    HTH,
    Colin
