ShaneA_214896's avatar
ShaneA_214896
Jan 23, 2017
1 GBPS load balancing throughput
Can F5 provide minimum 1 Gbps load balancing throughput and can be scalable to 10 Gbps with license key without changing the hardware?
  • Yes. Talk to an F5 Solutions Engineer. Your hardware can change depending on your requirements like SSL Transactions per second, L7 Connections/Requests per second.
