XFF and efficiently group code/iRule
Hi iRule gurus -
Was wondering if anyone can help me take and consolidate/put together the three code section efficiently. It seems there are too many "if" section just to do the same function.
What is needed is broken down into 3 section. They are as follows.
section 1: Validate pool members, and if all are down, redirect to a maintenance page.
section 2: validate the IP address in XFF (there are two IP in an XFF, the first is the proxy IP, and the second is the real connecting client IP address. Based on the second IP (which is listed in a data group called "DG_RESTRICTED_URI"), allow access to the URI, also defined in another data group called "DG-XFF-ALLOWED-IP-LIST".
Section 3: Does the same as section 2, however this is a little different. Instead of matching the URI in a data group, i want to specify it in the code since there is only one, and based the IP also in an allowed IP data group, redirect/allow to another URI.
Here are the code. I have not tested this yet since before we do, we have to move it to an external service that provides proxy (similar to incapsula).
Note that the info in the data group was modify and IP 1.1.1.1 and 2.2.2.2 were used to represent the real IP of the outside of the FW. The reason for this is outbound request from inside needs to go out and to an external provider hence the need for XFF to distinguish who the internal users vs external users are, and if they match the DG, they get access to the URI in the other data group.
Thanks all! Tony
ltm data-group internal DG-XFF-ALLOWED-IP-LIST {
records {
1.1.1.1/32 { }
2.2.2.2/32 { }
type ip
ltm data-group internal DG_RESTRICTED_URI {
records {
/URI1 { }
/URI2 { }
/URI3 { }
/URI4 { }
/URI5 { }
/URI6 { }
type string
Section 1 when HTTP_REQUEST {
if { [active_members MYPOOL-PORT-443] < 1 } {
HTTP::redirect "http://maintenance-page.company.com" }
log local0. "Redirect to maintenance page when all pool members is down: [HTTP::host]"
Section 2 if { [class match [HTTP::uri] eq "DG_RESTRICTED_URI"] } {
if { ([HTTP::header exists "X-Forwarded-For"]) and ([HTTP::header values X-Forwarded-For] ne " ") and ([class match [getfield [HTTP::header values X-Forwarded-For] " " 1] eq "DG-XFF-ALLOWED-IP-LIST"]) } {
log local0."[HTTP::header values X-Forwarded-For]"
pool MYPOOL-PORT-443
Section 3 -- This section does not use a data group for a URI list, there is a specific match listed below as "/URI1/URL2/PORTAL/ADMIN" that needs to match exactly if { [class match [HTTP::uri] eq "*/URI1/URI2/PORTAL/ADMIN*"] } {
HTTP::redirect "https://[HTTP::host]/SECRET/URI1/URI2/ADMIN/"
reject
log local0. "Client IP Discard: \ [HTTP::uri] [HTTP::header values X-Forwarded-For] -> [IP::local_addr]:[TCP::local_port]"
