Technical Forum
Custom Alert Banner
XC - 'TCP proxy without SNI is not supported on public network with shared VIP' when tcp lb?
Hooni_L
Cirrus
Cirrus
Hi
I used free plan account, so I want making tcp loadbalancer.
I don't understand 'tcp proxy without SNI is not supported' messages.
Setting Valuse :
Origin pools IP is 'AWS EC2 Public IP'
'SNI and Default LB choice values'. is disable
below is XC error log.
We found 1 error
For tcp_loadbalancer default/tcp-lb-hooni configuration for child object virtual_host ves-io-tcp-loadbalancer-tcp-lb-hooni is wrong - TCP proxy without SNI is not supported on public network with shared VIP
Show Less
�CreateResource: Failed transaction handling tcp_loadbalancer: STM Error, PreDBUndo Error: %!s(<nil>): Applying transaction function: rpc error: code = InvalidArgument desc = TCP proxy without SNI is not supported on public network with shared VIP<2023-01-17 08:35:01.780482112 +0000 UTC m=+3464340.473876158 >
How can I next step?
1 ACCEPTED SOLUTION
Hooni_L
Cirrus
Cirrus
I found ' Where to Advertise the VIP' options and resolve this issues.
change option from 'Advertise On Public' to 'Advertise Custom'
2 REPLIES 2
Hooni_L
Cirrus
Cirrus
Thanks for the update! I'm sure your follow-up will help a future user.
