Sort By
- RaghavendraSY_7Cumulonimbus
Can you please provide output for below command:
tmsh show /net interface
Please provide the ltm logs when service bcm56xxd got restarted.
- RaghavendraSYAltostratus
I'm assuming you have blades that have the ability to swap between 4x 10Gb ports and 1x 40Gb ports?
If so, the answer is yes. we recently installed new blades and it seems to require rebooting the services to switch the hardware from 40Gb and the 4x 10Gb breakout.
HTH
