18-Mar-2020 10:39
Excuse my ignorance. We created an irule years ago. It has worked well. We are moving data centers and I need to recreate the same. I don't know where to find the "private_net" file listed below. I want to compare that with what our new IP structure will be so I can duplicate.
ltm rule selective_snat_internal_nets {
when CLIENT_ACCEPTED {
if { [ class match [IP::client_addr] equals private_net] } {
snat automap
Solved! Go to Solution.
18-Mar-2020 13:02
It is a internal data group that is on the F5 by deafult. It is located under:
iRules>>Data Group List
Is basically an address list of the private subnets:
10.0.0.0/8
172.16.0.0/12
192.1468.0.0/16
18-Mar-2020 11:55
It seems to be Data Group file. It can be found under,
System > File Management > Data Group File List.
Hope it helps!
Mayur
18-Mar-2020 13:02
10.0.0.0/8
172.16.0.0/12
192.1468.0.0/16
18-Mar-2020 13:20
No luck. I can't even find the /system directory. Does anyone have the FULL path?
18-Mar-2020 14:45
If you are trying to see the setting via the terminal
Here is where external data groups Files are stored:
/config/filestore/files_d/Common_d/data_group_d
Internal data groups are stored as part of the bigip.conf
you will need to search for ltm data-group internal /Common/<data group name> within the conf file.
Through the REST Api you can see the contents from this path
https://<f5.addess>/mgmt/tm/ltm/data-group/internal/
https://<f5.addess>/mgmt/tm/ltm/data-group/external/
From there you can drill down further to specific data_groups
19-Mar-2020 06:51
Thank you Beaker. This is what I was looking for. Sadly, I still can't find the file yet but we are in managed environment and don't have full access. This is enough for me to point our DC vendor in the right direction.
