18-Jun-2020 11:55
Hi All ,
If I have to change the default TCP timers to greater than its default value (in new custom monitor) , what are the different timers I can set , Can I use the random values ?
Say for default TCP monitor :
Interval : 5sec
timeout : 16 seconds ..
So can we use interval : 30sec , timeout: 60 sec ?
22-Jun-2020 10:15
you can use all the values you want (within some limits)
just remember to set the timeout at X times to interval + 1
so with the interval of 30 you would end up at 91 for the timeout.
in that way you allow for three missed attempts until the monitors flags it as down.
08-Jul-2020
11:59
- last edited on
24-Mar-2022
01:11
by
li-migration
