Technical Forum
WebEX SSO integration
X3n0m0rp4
Hi Folks,
Anyone have a recent guide on integrating F5 APM as an IdP for Webex?
Only came across ones from Cisco, documents look straightforward but are for v11 and i am looking to implement in a test lab running v17.(x)
thanks all 👍
1 ACCEPTED SOLUTION
3 REPLIES 3
Leslie_Hubertus
Community Manager
Community Manager
Hey @X3n0m0rp4 - first, fun username! Second, are you looking for something more recent than Dec  '21? I found this link on the WebEx site, but let me know if it isn't what you need.
Leslie_Hubertus
Community Manager
Community Manager
X3n0m0rp4
Hi Leslie, Thanks for your feedback - I had saw those documents and we managed to resolve but it was a combination of bad documentation and our wintel team using different AD attributes.
So after messing around with SAML Decoder and some button pushing, our fix was in Assertion settings, where i amended the "Assertion Subject Value" to the UPN attribute and then do the same in the SAML attributes. It then burst into life 👍
Thanks again
