Abhisar's avatar
Abhisar
Jun 21, 2020
Solved
WAF - URL advance option - header based content profiles
Dear All,
We have WAF Policy with 600 + URLs with header based content profile - default action set to - apply value and content Signatures.
I want to change that default action to Form Data. So is there is fastest way to do that?
Please advise.
Thank You,
Abhisar
  • personally i would look into exporting the policy, looking at the code in the xml file and see if you can do a find and replace on that. if that isnt possible a script to make the change might be an option.
  • Hello Abhisar,
    What version of BIG-IP do you have?
    Starting version 13.0.0 you can update all needed URLs in ASM policy via sending next RESTAPI request to https://mgmt_ip/mgmt/tm/asm/policies/policy_id/urls?appendnested=1:
    PATCH /mgmt/tm/asm/policies/policy_id/urls?appendnested=1 HTTP/1.1
    Host: mgmt_ip
    Content-Type: application/json
      "urlContentProfiles": [
          "headerValue": "*",
          "headerName": "*",
          "headerOrder": "default",
          "type": "form-data"
    Pay attention that appendnested=1 QS parameter is needed in this case, because without it all other (not default) header based content profiles will be deleted.
    Also, you can use additional $filter= QS parameter to filter out all needed URLs
    Thanks, Ivan
  • Thank you Ivan, I would love to try this.
    For time beging I exported the policy and changed config and imported again.
