22-Dec-2020 02:19
Can we protect SQL server with ASM module?
on port 1433.
Actually I have faced an issue while doing the same.
After applying http profile unable to access SQL server.
and then can't apply ASM profile.
22-Dec-2020 11:18
ASM secures HTTP traffic. The HTTP profile is needed for ASM...but is your virtual server an HTTP server?
22-Dec-2020 11:20
In other words, does your VS use HTTP?
23-Dec-2020 03:07
No, it use port 1433. connect via agent or app server.
23-Dec-2020 12:49
What kind of requests does you server accept?
Could you provide an example of simple request from tcpdump?
If it accepts HTTP request, then YES, you can use ASM for its protection. If NO, then most probably you can not use ASM.
