Technical Forum
Custom Alert Banner
WAF Learning speed
THE_BLUE
After how many clicks the WAF will learn the clicked url / parameter and so on ?
Is it depend to Learning Speed ( fast , medium and low ) in policy settings ?
and how to increase the learning to allow WAF to learn from first click ?
Does Enforcement Readiness Period will help to increase the learning?
3 REPLIES 3
Lidev
MVP
MVP
double post , already answer : https://devcentral.f5.com/s/question/0D51T00008T7HhKSAV/waf-learning-speed.
Also check the option "Trusted IP" as you can make the ASM learn new things with just 1 access to an object in the website from a tusted IP maybe from the DEV or Devops team:
https://techdocs.f5.com/kb/en-us/products/big-ip_asm/manuals/product/asm-implementations-13-1-0/9.ht...
Dear Nikoolayy1
Many thanks.
