Technical Forum
VPN to Azure using BGP
Edouard
MVP
MVP
Does any one has set up this two VPN links to Azure using BGP ?
https://docs.microsoft.com/en-us/azure/vpn-gateway/vpn-gateway-bgp-overview
I am not sure yet where should I set the BGP peer yet.
Regards,
Edouard,.
0 REPLIES 0
