29-Jun-2020 11:32
We're running BigIP v.12.1.3.2 and we're seeing the Virtual Servers in the GUI, but when using "list ltm virtual VS-1" in TMSH, none of them is coming up.
Has anyone run across a similar issue?
Thanks.
29-Jun-2020 18:12
Strange. May be you are not searching with right virtual name?
Run below command and search it.
list ltm virtual one-line | grep "virtual-ip address"
Hope it will help else check in config file "bigip.conf"
