28-Jan-2020 01:11
I am getting Validation Error: Malformed XML data for XML request having Katakana/Hiragana characters in it.
Below error lines from the request report from F5
<v11:frgnfirstName>マレーシア シンガフール</v11:frgnfirstName>
<v11:frgnlastName>ç¯ ç”°</v11:frgnlastName>
28-Jan-2020 13:00
Do you have an XML profile configured?
Do you have the correct schema and wsdl configured in the XML profile?
You may need to set the internal ASM variable relax_unicode_in_xml to 1
From the version 12.0.0 release notes:
> So that you can bypass unicode validation on XML and JSON profiles, we added two internal parameters:
28-Jan-2020 23:48
Thank you S Blakely,
To answer you question,
Do you have the correct schema and wsdl configured in the XML profile? - YES
Actually we send Katakana & Hirahana Japanese characters in XML like below,
<v11:frgnfirstName>マレーシア シンガポール</v11:frgnfirstName>
<v11:frgnlastName>篠田</v11:frgnlastName>
It gets converted to below,
Request is blocked at F5 with Validation Error: Malformed XML data
Will relax_unicode_in_xml to 1 resolve this issue and F5 will pass the request to services end?
Br,
Nakul
29-Jan-2020 14:19
You will need to test to determine whether the issue gets resolved.
But I'm pretty sure it might.
28-Jan-2020 23:32
Hi All,
Thanks for explanation. In order to correct you need configure and restart ASM.
/usr/share/ts/bin/add_del_internal add relax_unicode_in_xml 1.
/usr/share/ts/bin/add_del_internal add relax_unicode_in_json 1.
bigstart restart asm
28-Jan-2020 23:40
Thank you Samir!!
