Using Remote Logging How Often are Log Entries Sent To Remote Logging Server
We have a F5 that sends it's syslog entries to Splunk. We only use remote logging not the analytics. How often does the F5 send the entries to the remote Spluink logging server. I think it writes the entries both locally and to the remote logging server at the same time. Is that correct? Thanks,
- Lidev
Nacreous
Hi DH,
Yes, you right
https://support.f5.com/csp/article/K86480148
the syslog-ng service creates the server as a separate destination for log messages, so in addition to logging locally, the BIG-IP system will also log to the remote device.
