26-Aug-2021 02:38
Hi, I am configuring a virtual server that uses an iRule to present an html file of a maintenance page.
The html is in the big ip as an iFile. The page is working properly with the following simple iRule:
HTTP::respond 200 content [ifile get Construction-html] "Content-Type" "text/html"
I am trying to use a different iFile as the icon at the tab of the web page. I saw in this kb https://support.f5.com/csp/article/K25815544 that I need to add this:
HTTP::respond 200 content [ifile get <icon_iFile>] "Content-Type" "image/x-icon"
My question is how can I respond with both of those iFiles in a way that the html file will show the web page and the other file will show the icon.
Is it possible?
Thank you,
Raz.
Solved! Go to Solution.
26-Aug-2021 05:24
Try this
switch -glob [string tolower [HTTP::uri]] {
"*/favicon.ico" { HTTP::respond 200 content [ifile get <icon_iFile>] "Content-Type" "image/x-icon" }
default { HTTP::respond 200 content [ifile get Construction-html] "Content-Type" "text/html" }
26-Aug-2021 05:24
Try this
26-Aug-2021 07:14
It works! Thank you very much.
