Santhosh's avatar
Santhosh
May 18, 2020
URI Replacement for every request
Need help on URI replacement. the below irule is only working for the initial request but not the other request after getting in to the application somehow.
   set http_uri [HTTP::uri]
   set http_host [string tolower [HTTP::header "Host"]]
   if { [HTTP::uri] matches_glob "/profile" } {
       HTTP::uri [string map {/profile /account} [HTTP::path]]
      SSL::disable serverside
       pool ABCD
else {
Pool XYZ
