22-Aug-2017 03:10
I am still a bit confused on using universal persistence and the persist command. The big question is :"Can the command persist [add] uie be used in a standard iRule, or does the iRule in which the commands are used, needs to be connected to a universal persistence profile in which the iRule is connected?
22-Aug-2017
03:19
- last edited on
05-Jun-2023
22:34
by
JimmyPackets
persist uie
/ persist add uie
can be used on a standard irule or by a Universal persistence profile.
persist uie
persist add uie
