Mohanad's avatar
Mohanad
May 13, 2020
unexpected redirection
Hi Everyone
this the network topology
Client (1.1.1.1) -----> F5 ASM (192.168.10.10:443) -----> Backend Server (10.10.10.10:8443)
F5 is performing port translation and applying web security policy
When client connect to "https://192.168.10.10/DRNClient" it's working successfully, then press on a button called "start DRN Client" to download java file to open the application , URL is changed to "https://10.10.10.10:8443/DRNClient/DrNClient.jnlp" and timed-out because we allow only inbound traffic for 192.168.10.10:443
i want to understand the issue and how to fix using F5
Thanks,
Mohanad
  • Hi,
    The VS port and address translation act only on network layer, while html content is at application layer.
    So you may need to rewrite the html content to proxy the explicit internal links.
    One option is by using a stream profile to rewrite that content.
    e.g.
        STREAM::disable
        HTTP::header remove "Accept-Encoding"
    when HTTP_RESPONSE {
        if { [HTTP::header Content-Type] contains "text" } {
            STREAM::expression {@https://10.10.10.10:8443@@}
            STREAM::enable
    On server side:
    <a href="https://10.10.10.10:8443/DRNClient/DrNClient.jnlp">start DRN Client</a>
    On client side:
    <a href="/DRNClient/DrNClient.jnlp">start DRN Client</a>
    See:
    https://clouddocs.f5.com/api/irules/STREAM__expression.html
    Regards.
