kaoutar's avatar
kaoutar
Icon for Cirrus rankCirrus
Dec 28, 2020
TSURLCK_test cookie
Dear All,
please can you explain to me what the "TSURLCK_test" cookie means, when i scanned my web app, it reveals that this cookie is present in additions to those ASM main and frame cookie TSXXXXXXXX
  • _test, this looks to be something manually inserted. If web app can be accessed directly bypassing the VS, try it and see if the cookie present, this should confirm who is inserting it. Or you can take the long route to check your VS setup Irules and profiles.
