wrightnz_34708's avatar
wrightnz_34708
Sep 02, 2010
Top talkers
Hi folks
Couldn't find an appropriate forum name to pose this question ... here goes anyway
Background:
We occasionally have rouge web crawlers generating large amounts of traffic and affecting the performance of our Big-IP 6400 HA pair .... robots.txt not taking care of some of these.
Questions:
1. Is there a way to determine 'Top Talkers' or IP addresses generating the most traffic on a Big-IP LTM?
2. Is there an irule which can drop these blaclisted IP's as they try to connect?
Suspect I may have to do this on the firewall but wanted to check first if possible to do from the Big-IP
Cheers!
  • hoolio's avatar
    hoolio
    Sure, you could do this with an iRule on LTM. If you're on 10.x, you can use the table command to save this info in a session table. For 9.x, you can use a global array.
    You can check the iRule codeshare and table wik page for more info.
    Codeshare
    http://devcentral.f5.com/wiki/default.aspx/iRules/codeshare
    http://devcentral.f5.com/wiki/default.aspx/iRules/high_performance_rate_limiting.html
    http://devcentral.f5.com/wiki/default.aspx/iRules/Version_9_Throttle_on_Requests_Per_Second.html
    Table command info
    http://devcentral.f5.com/wiki/default.aspx/iRules/table
    http://devcentral.f5.com/Default.aspx?tabid=63&articleType=ArticleView&articleId=2375
    Aaron
