TCP KeepAlive - Avoid long client connection without data
Hello,
I have virtual servers with type "Standard", TCP profile and HTTP profile. (BigIP LTM 1600, v 11.2.0)
The problem is that some users stay connected indefinitly using TCP keep alive.
For the TCP profile, the max idle time is set to 300sec, but the client reset the connection idle time sending a tcp keepalive...
- Is there a way to define a maximum duration for connection when no data is sent/received...?
- How can I show the creation date of all tcp connection ? (to identify long duration....)
Thanks!
- What_Lies_Bene1
Do you know how often the keepalive is sent? You could reduce the TCP profile Idle Timeout to below it's value? - What_Lies_Bene1
OK, so, how do we know when the last request has been sent? - Hamish
Cirrocumulus
If its http (with an http profile) you can separately set the max number of http requests and the max http idle time (which is separate from the tcp idle times).
H - fabianlumy
The BigIP should be able to know for a given connection context when the last http response has been sent ? And then with a timer, force a connection to close when timeout.
This is how the keepalive works on webserver... - What_Lies_Bene1
Did you see Hamish's post above. I can't confirm the HTTP Idle Time setting as my VE is down but it sounds like what your looking for. - fabianlumy
@Hamish: I can define a "max-requests" to apply to my http profile, but how can I set a max idle time to http profile ...?
show sys version
Sys::Version
Main Package
Product BIG-IP
Version 11.2.1
Build 862.0
Edition Hotfix HF2 - Kevin_Stewart
Employee
I'm not sure there is an HTTP timeout control, and what you're asking for isn't trivial.
Aside from that, I can think of potentially two options (albeit sub-optimal):
1. Force a "Connection: Close" header in HTTP responses. Probably not the best performance you'll get since you're not allowing any keep-alives at all, but you should be able to thwart the client's keep-alives.
2. A timer function in iRules. I would stress that this could be potentially dangerous, if not simply memory intensive, so please test vigorously if you choose something like the following:when HTTP_RESPONSE { if { not ( [info exists timer] ) } { set timer [after 8000 { TCP::close }] } } - fabianlumy
@Kevin: Thanks for your suggestion,
The first proposition is not acceptable since keepalive are really a good option
The second one, like you said, seems to lead in a dangerous way (with reject in place of TCP::close()) but could work...
I'm really surprised, I think that all the public website delivered using BigIP should not allow indefinite connection ?
In your case ? How do you do ? - Kevin_Stewart
Employee
I think it's safe to say that since HTTP isn't a persistent protocol by nature, it isn't generally a problem for ~most web applications. So when you say "indefinite connections", are simply referring to HTTP keep-alives, or some other method of keeping the TCP session open? - fabianlumy
Actually I'm refering to keeping TCP session open.
I've already tried to control this with the cisco asa which is before the BigIP, but the "tcp idle time" considers the tcp keepalive (tcp trame without data) as activity, so like the BigIP, the idle time is continuously reset..
