Technical Forum
TCP::Close when pool is down
Roflcopter
We have a scenario where a remote client will make a TCP connection to the F5 and in turn a backend server.
We are using MBLB to load balance the traffic to backend servers.
This TCP connection could stay open for a while and it could be a while between messages. This works great so far.
What we need to finish it off though is in the event that all pool members are down there is a TCP::Close sent back to the clients.
I have got this working by using the LB_FAILED as below -
when LB_FAILED {
log local0. "LB FAILED"
if { [active_members MY_POOL] == 0 } { TCP::close log local0. "TCP CLOSED" } }
However this only works if a new message is received once the pool members are down. It doesn't trigger off a TCP::Close if the pool members go down.
I can't find a way to use the pool down event to then trigger off a TCP::Close.
4 REPLIES 4
iaine
MVP
MVP
Have you tried setting Action on Service Down in the Pool settings to Reset...?
Jad_Tabbara__J1
If I understood well, you want to "reset" all existing connections as soon as all pool members of your pool goes down ?
If that's what you are looking for, then your irule wont work because the irule will run only when receive a "new connection" on the VS.
If you want to reset all existing client-side connections, as "iaine" said you could try to set the pool feature "Action On Service Down" to "reject".
Otherwise, If you want to manage this from you irule you need to call an external script within your irule using iCall for example. Then from this script, you can use tmsh command to reset all connections of a particular VS.
`tmsh delete sys connection cs-server-addr "VIP_addr"`
Hope it helps
Roflcopter
I the end we stuck with the rule above.
Dint you try the Action on Service Down - Reject option. Refer the "JTI" options.
