wallst234_11461
May 14, 2013Nimbostratus
Sync config/pending changes from TMSH?
I have 2 LTM 1600 BIG-IP 11.2.0 Build 2713.0 Hotfix HF3 in active/standby mode. I periodically make changes to the active devce via TMSH and want to push those changes to the standby device. What is the correct command?
From TMSH : sys config-sync
returns: Syntax Error: unexpected argument "config-sync"
