22-Feb-2011 04:43
I need to configure an Snat Pool and Snat to translate a whole subnet including the network address and broadcast address the external networks are 200.166.92.128/25 and 201.15.234.128/25, the internal network is 172.23.180.128/25, the translations always correspond to the last octect, ex:
200.166.92.128 --> 172.23.180.128
201.16.234.128 --> 172.23.180.128
On the Snat Pool configuration the member list do not accept subnets, only hosts, but when I'll configure the Snat I can specify a network.
If I create a Snat Pool with all the hosts in this subnet and then create a Snat with the addres list for the whole 172.23.180.128/25, will the translation work for all ips according to the last octect? or I'll have to configure one by one?
Thanks!
22-Feb-2011
08:29
- last edited on
31-May-2023
15:40
by
JimmyPackets
You'd need to use an iRule for this. You could basically check in CLIENT_ACCEPTED to see if the client IP (IP::client_addr) is in a datagroup of source IP address/networks to SNAT. You could then apply the SNAT using logic like this:
when CLIENT_ACCPTED {
Check if client IP is in address datagroup of allowed source addresses
if { [class match [IP::client_addr] equals allowed_snat_clients_class] }{
Take the last octet of the client IP and use that for the SNAT address
snat "172.23.180.[getfield [IP::client_addr] . 4]"
Note that you don't need to define any SNAT object to use this iRule.
Aaron
22-Feb-2011 10:23
Good to know there is a way to do it, I'll have to study iRules a little bit, as I don't have time this occasion, I'll configure one by one.
Thankyou very much.
Felipe
