Raymond_Cheung_
Apr 25, 2005SSL offload: http header replace
I am doing SSL offload on on of our site.
BigIP is forwarding https request from the client to the server using https.
I need to write an iRule to change the http header for the http request from http to PROXYHTTPS.
Will I be changing the http Request or the http response?
HTTP::header replace http PROXYHTTPS
or
when HTTP_RESPONSE {
or
Both of the irule are not right
I will be applying the iRule to the Virtual Server with clientssl proxy.
I am new to iRule.
Please help!
Raymond
- unRuleY_95363Historic F5 AccountI'm rather confused about what your asking. Can you try to elaborate more on what it is you want to do?
Are you wanting the BIGIP to rewrite the request to a proxy HTTP server?
