JRahm
Mar 22, 2005Admin
SSL, Cookie persistence, and Redirection
I have two sites that use BigIP, with 3DNS doing the global load balancing. We have no global persistence due to the ldns design of our clients, so request are round-robin currently. The application that we are delivering does a refresh every 60 seconds, and is pulling data subsequently from each site every other minute. Our db replication isn't that fast, so the data is inaccurate from the user perspective. All clients connect via SSL. I have one pool of servers at each location, and am doing cookie persistence to maintain users locally. I am trying to write a rule that will evaluate the cookie that the client is sending, determine if the cookie is on a local server or not. If it is local, persist to that server, if it is not, check the array for the server vip of the other location and redirect to that vip. If there is no cookie, load balance to the local pool. Below is my work flow and the chunks of code I have thus far. Can anyone offer assistance in helping me through this rule? Thanks.
Work Flow
Terminate SSL
Inspect HTTP Header for cookie mycookie and decrypt it.
Exist?
NO --> use pool gdss2
YES -> Is server returned in cookie in the local BigIP node list?
YES --> persist to local
NO --> Look in array for vip for the server returned in cookie,
reencrypt cookie, send to client and redirect to that vip.
when RULE_INIT {
array set ::CLIENT_SERVERS {
SITE B CLIENT SERVERS
SERVER IP SERVER VIP
10.10.70.128 10.10.69.50
10.10.70.129 10.10.69.50
10.10.70.130 10.10.69.50
10.10.70.131 10.10.69.50
10.10.70.132 10.10.69.50
10.10.70.133 10.10.69.50
10.10.70.134 10.10.69.50
10.10.70.135 10.10.69.50
SITE A CLIENT SERVERS
10.10.22.130 10.10.21.50
10.10.22.131 10.10.21.50
10.10.22.132 10.10.21.50
10.10.22.133 10.10.21.50
10.10.22.134 10.10.21.50
10.10.22.135 10.10.21.50
if { [HTTP::cookie exists "mycookie"] {
HTTP::cookie decrpt "mycookie" "iggus99!"
Pull out servername, set to $node (first string in array record)
if { not [info exists $::CLIENT_SERVERS($node)] {
log "Altered Cookie: $node"
reject
return
if server in cookie is remotely defined {
$node_val second string in array record
redirect to "https://$::CLIENT_SERVERS($node_val)/[HTTP::uri]/"
if server in cookie is locally defined, persist to that server
else
use pool mypool
when HTTP_RESPONSE {
HTTP::cookie encrpt "mycookie" "iggus99!"
