Technical Forum
Custom Alert Banner
Solved
gsventkauskas
Solved
1 REPLY 1
Leslie_Hubertus
Community Manager
Community Manager
Would you be willing to share your solution with the community in case another user has the same issue in the future, or should I take the post down for you?
