rajeev_81179
Sep 02, 2009snmpwalk Timeout: No Response
We just upgraded F5 in our DC, from 5100 to 6900 (ver 9.x) with the same upgrade. When i run the (snmpwalk -c YOUR_COMMUNITY_STRING -v 1 YOURDEVICE_IP)
snmpwalk -c ASP -v2c 1.2.3.4 on the active device it says no response from host.
Timeout: No Response from 1.2.3.4
But when I run the same command on the standby unit, it works fine and SNMP is working on the standby unit. I am able to ping both the devices.
I restarted the SNMPD service and checked config/snmpd.conf file and compared both the files and the settings seem to be fine, infact I synced the box(active) FROM PEER(standby) and still have the same issue.
Any help is much appreciated....
Sort By
- The_Bhattman
Did you allow 127.0.0.1 on the snmp settings? - L4L7_53191
Is 1.2.3.4 the floating IP address by chance? I've run into this before (a long time ago, mind you...). - rajeev_81179
Yes, i have allowed 127.0.0.1 in teh snmp settings..i copied the config from 5100 to 6900 as it was a migration and the standby unit is working fine.....as mentioned i even synced the active from standby..... - rajeev_81179
Matt,
