23-Nov-2009 05:46
I have a LTM-setup (10.0.1) with a SNAT Pool containing 5 ip addresses. So each connection uses the next SNAT address (round robin).
But for persistent connections (source persistence), i'd like the LTM to use always the same SNAT address, and not to change it during the session. Otherwise some of my applications have problems with session management...
Is there a way to configure the SNAT pool in a way that persistent connection always keep their SNAT address?
Thanking you in anticipation, regards
Marc
23-Nov-2009 05:51
Here is a related post:
http://devcentral.f5.com/Default.aspx?tabid=53&view=topic&postid=86374&ptarget=86389
Aaron
23-Nov-2009 06:11
Do you think mapping the source IP address to a SNAT IP would work for you (assign 1/x IP addresses to one SNAT IP)? If so, I can put together an example. Else, the UIE session persistence method would take a bit longer to give an example for.
Aaron
23-Nov-2009
07:29
- last edited on
31-May-2023
14:13
by
JimmyPackets
when CLIENT_ACCEPTED {
Create some snat name to IP variables
set snat0_ip 1.1.1.1
set snat1_ip 2.2.2.2
set snat2_ip 3.3.3.3
set snat3_ip 4.4.4.4
set snat4_ip 5.5.5.5
Test with a dummy client IP address
set client_ip "10.11.12.13"
log local0. "\$client_ip: $client_ip"
Scan the dummy IP address for each octet
scan $client_ip {%[0-9].%[0-9].%[0-9].%[0-9]} a b c d
log local0. "result: \[expr {$c % 5}\]: [expr {$c % 5}]"
Use modulus 5 on the third octet
log local0. "Snat command: snat [set "snat[expr {$c % 5}]_ip"]"
Apply the SNAT IP to this connection
Once you're done testing, you can replace the $client_ip variable with [IP::client_addr]. You could also experiment with using a datagroup to store the SNAT addresses or maybe an array.
Aaron
23-Nov-2009
08:16
- last edited on
31-May-2023
14:13
by
JimmyPackets
Use a local array to configure the 5 SNAT addresses
set snat_ips(0) 1.1.1.1
set snat_ips(1) 2.2.2.2
set snat_ips(2) 3.3.3.3
set snat_ips(3) 4.4.4.4
set snat_ips(4) 5.5.5.5
Use getfield to parse the third octet from the client IP address
Get the modulus of the third octet against the number of the SNAT IPs in the array
set snat_number [expr {[getfield [IP::client_addr] "." 3] % [array size snat_ips]}]
log local0. "Client IP: [IP::client_addr], SNAT number $snat_number, SNAT IP: $snat_ips($snat_number)"
Apply the SNAT
snat $snat_ips($snat_number)
Aaron
25-Nov-2009 05:50
Thank you very much for this proposal!
I currently use a general SNAT for all origin adresses to my SNAT pool.
So now, i have to disable this SNAT and add the iRule to all my VS?
Regards
Marc
25-Nov-2009 08:28
You could use this specific SNAT rule on any VIP where you want to "persist" clients with the same SNAT IP over multiple connections. The more general default SNAT would take lower precedence than SNAT called from an iRule. So you could leave the default SNAT enabled for any other VIP which you don't need to use the same SNAT pool IP for each client.
Aaron
25-Nov-2009 08:28
13-Apr-2011 23:24
http://devcentral.f5.com/wiki/default.aspx/iRules/snat_pool_persistence
Aaron
14-Apr-2011 08:34
http://devcentral.f5.com/wiki/default.aspx/iRules/Exchange2010_SNATPool_Persist.html
14-Apr-2011 13:25
Aaron
14-Apr-2011 14:27
31-Aug-2023 00:30
I know this post is very old , but i got into the same issue but the internet search for the irule has landed over here.
My goal is to match client IP to SNAT (one to one mapping). I found an irule, but that is very long (manual typing and for bigger subnet cannot apply since that will be longer than 65536 characters which irule can take).
if { [IP::addr [IP::client_addr] equals 172.16.56.10/32] }{
snat 172.16.56.10
if { [IP::addr [IP::client_addr] equals 172.16.56.11/32] }{
snat 172.16.56.11
if { [IP::addr [IP::client_addr] equals 172.16.56.12/32] }{
snat 172.16.56.12
"and till all the one to one mapping"
However, this is not useful for longer subnets.
Is there a way to match the third and last octect of the IP of the client to SNAT IP.
The above irule shows about the thrid octect only , is there a way to match 3rd and 4th octect?
Zanoob
