wtwagon_99154
Dec 09, 2008Nimbostratus
Slow GUI?
Does anyone else have problems with a slow GUI? I am running an HA Pair of 3400s on code version 9.4.3 and the GUI takes an average of 5-7 seconds to move throughout on each option. It is specifically worse when we have a decent amount of traffic passing through it from the Internet (200 Mbps for example).
I opened up a ticket to investigate, and the troubleshooting steps were as follows:
1) Disabling the 'Display Host Names When Possible' checkbox.
We actually use/need this functionality, but I disabled it and did not feel any improved functionality.
2) Restart Tomcat in case their were some hung processes
Unfortunately, restarting tomcat did not fix the issue.
3) full_box_reboot -- haven't tried this yet, but I'm not sure if rebooting the box will fix any problem because we've been through a couple reboots without any resolution of GUI slowness.
With that being said, we typically run at about 60% idle on the CPU. If I run a top command and move around throughout the GUI, the CPU will typically drop to around 0% idle as I do this.
Has anyone else experienced a slow GUI, and if so, do you know how to remediate it? Thanks.
