One way to optimize this rule would be to remove the check for the host. If all traffic on the virtual is going through example.mycompany.com, then the first if is overkill. You might say it's just one string compare, but for 1000's of connections it can add up.
if { [HTTP::uri] equals "" or [HTTP::uri] equals "/" } {
HTTP::redirect https://example.mycompany.com/login_page
Another alternative to doing two string comparisons would be to do a single string length command and test for a length less than or equal to 1. If there is a uri it is either empty or starting with a slash.
if { [ string length [HTTP::uri] ] <= 1 } {
If you wanted to dig a little deeper, then you could try using the "string index" command testing for the 3rd character. If it is empty, then you know there is no trailing portion on the uri.
if { [ string index [HTTP::uri] 2 ] equals "" } {
I'll leave it to unRuleY to check which one is more optimal.
*Note, I haven't tested these so you might want to give each a run through to see which works.
If you are running multiple hosts on this virtual then you might want to leave in the host comparison.
-Joe
