06-Oct-2021 05:00
I´ve a scenario that requires that the APM sends a cookie back to the client after the user has been authenticated by the APM but before the user "hits" the backend server.
Normally I would have use the "when HTTP_RESPONSE" to insert the cookie to the client but that requires the traffic has been sent by the backend server.
//Cheers Mikael
18-Oct-2021 04:07
we've an IRule like this:
when ACCESS_ACL_ALLOWED {
set user [ACCESS::session data get "session.logon.last.username"]
when HTTP_REQUEST_RELEASE {
HTTP::header insert "X-Forwarded-User" $user
when HTTP_RESPONSE_RELEASE {
log local0. "[HTTP::status] [HTTP::header "Location"]"
so maybe you can change this to your needs, for example instead of "header insert" "cookie insert"
18-Oct-2021 04:49
Hi kgaigl and thank you for your reply.
I want the APM to send back a cookie after the client are authenticated but before the client reaches the backend server, so I can´t use
or
when HTTP_RESPONSE
Any more ideas?
//Mikael
