01-Nov-2022 15:01
Dear all,
I'm looking to secure my SMTP server using STARTLS, on the client-side and the server-side. The SMTP server has been configured to listen on port 25 and supports STARTTLS (using self-signed certificate on the server itself). From the F5-LTM, I can create a SMTPS profile to enable the TLS feature on port 25 on the client-side, but I can't do it on the server-side.
Here is my SMTPS profile config:
ltm profile smtps smtp-tls-25_smtps {
activation-mode allow
app-service none
defaults-from /Common/smtps
Here is my Client-SSL config:
ltm profile client-ssl smtp.domain.com_CS {
app-service none
cert-key-chain {
smtp.domain_Sectigo_cert_chain_0 {
cert smtp.domain.com
chain /Common/Sectigo_cert_chain.crt
key smtp.domain.com
smtp.domain_Sectigo_cert_chain_1 {
key smtp.domain.com
usage CA
defaults-from /Common/udes-default-clientssl_profile
inherit-ca-certkeychain false
inherit-certkeychain false
ssl-forward-proxy enabled
ssl-forward-proxy-verified-handshake enabled
Here is my Server-SSL config:
ltm profile server-ssl smtp.domain.com-proxy-fwd_SS {
app-service none
defaults-from /Common/udes-default-serverssl_profile
revoked-cert-status-response-control ignore
Here's my Pool config:
ltm pool smtp-25_pool {
description "Test de passerelles SMTP sur le port 25"
members {
smtpi-dev01_node:25 {
address 10.32.160.127
session monitor-enabled
state up
monitor /Common/gateway_icmp and smtp-25_hm
partition INFRA-DEV
Here's my Virtual Server config:
ltm virtual smtp-25_vs {
destination 1.1.1.1%1:smtp
ip-protocol tcp
last-modified-time 2022-11-01:17:36:56
mask 255.255.255.255
partition INFRA-DEV
pool smtp-25_pool
profiles {
/Common/tcp { }
smtp-tls-25_smtps { }
context serverside
context clientside
rules {
/Common/logging_clients_tcp_v3
serverssl-use-sni disabled
source 0.0.0.0/0
source-address-translation {
pool natpool-inside-vlan6
type snat
translate-address enabled
translate-port enabled
vs-index 36
When I issue the command:
openssl s_client -showcerts -starttls smtp -connect smtp-dev.domain.com:25
I got this result:
CONNECTED(00000003)
didn't found starttls in server response, try anyway...
139865767704464:error:140790E5:SSL routines:ssl23_write:ssl handshake failure:s23_lib.c:177:
no peer certificate available
No client certificate CA names sent
SSL handshake has read 0 bytes and written 324 bytes
New, (NONE), Cipher is (NONE)
Secure Renegotiation IS NOT supported
Compression: NONE
Expansion: NONE
No ALPN negotiated
SSL-Session:
Protocol : TLSv1.2
Cipher : 0000
Session-ID:
Session-ID-ctx:
Master-Key:
Key-Arg : None
Krb5 Principal: None
PSK identity: None
PSK identity hint: None
Start Time: 1667338630
Timeout : 300 (sec)
Verify return code: 0 (ok)
Doing the same command directly on the backend server, I got:
ONNECTED(00000003)
depth=0 CN = smtpi-dev01.domain.com
verify error:num=18:self signed certificate
verify return:1
verify return:1
Certificate chain
0 s:/CN=smtpi-dev01.domain.com
i:/CN=smtpi-dev01.domain.com
Server certificate
-----BEGIN CERTIFICATE-----
MIIFbDCCA1SgAwIBAgIUVujZu3QKSfTguvw+U67aQDl8d4swDQYJKoZIhvcNAQEL
-----END CERTIFICATE-----
subject=/CN=smtpi-dev01.domain.com
issuer=/CN=smtpi-dev01.domain.com
Peer signing digest: SHA256
Server Temp Key: ECDH, P-256, 256 bits
SSL handshake has read 2647 bytes and written 450 bytes
New, TLSv1/SSLv3, Cipher is ECDHE-RSA-AES256-GCM-SHA384
Server public key is 4096 bit
Secure Renegotiation IS supported
Compression: NONE
Expansion: NONE
No ALPN negotiated
SSL-Session:
Protocol : TLSv1.2
Cipher : ECDHE-RSA-AES256-GCM-SHA384
Session-ID: E9C2D4E06675C447B026017E368AE3148F25A4118DB2D09FC53A1A97AD22165B
Session-ID-ctx:
Master-Key: E12AFB816901DAABAA5BC25F7CF144138E1F1FAF82FA62A3CB734B445FC7420616B571E6377FE2E08257D08DD2B1B651
Key-Arg : None
PSK identity: None
TLS session ticket lifetime hint: 1 (seconds)
TLS session ticket:
0000 - 90 89 7c db d6 aa b9 18-5a bf 98 35 04 c0 8f 5c ..|.....Z..5...\
0010 - 74 29 37 2e 30 5b 97 98-11 84 51 6e c2 57 90 e4 t)7.0[....Qn.W..
0020 - 18 33 fc 1b 64 be 35 2f-15 0a 2c b1 f2 7b f1 5b .3..d.5/..,..{.[
0030 - 2b 6f 69 da 5a 58 26 42-db 74 61 7e 63 f0 4c 75 +oi.ZX&B.ta~c.Lu
0040 - 85 d5 11 ae 0c a3 d4 69-cf 23 35 ad 58 05 40 44 .......i.#5.X.@D
0050 - 89 32 50 af c7 36 65 35-48 3e 1c c2 31 f3 d8 84 .2P..6e5H>..1...
0060 - 3a b6 3c 52 2f 3c 94 90-3f c6 77 e1 b4 9a 01 54 :.<R/<..?.w....T
0070 - 90 6a 0a c3 6e e3 20 1c-71 aa 66 7e bb 07 60 fe .j..n. .q.f~..`.
0080 - f3 41 e2 73 94 0f 25 f9-70 92 9c ac 01 ef 26 d2 .A.s..%.p.....&.
0090 - 42 c9 bd aa 84 41 79 21-05 09 a7 16 cd 31 7c 2c B....Ay!.....1|,
Start Time: 1667339374
Timeout : 300 (sec)
Verify return code: 18 (self signed certificate)
250 HELP
So I'm wondering how to have thin working. We are using port 25 for the client because we want to allow user to connect to the server in plain text (no SSL) as well as TLS (starttls). The communication to the backend servers can always be encrypted. I tried use the port 465 into the pool definition (SMTP server has been configured to listen on that port), but I got the same answer (didn't found starttls in server response, try anyway...) .
I think I will need to use some iRules to enable STARTTLS on server side, but I'm not sure how to configure it.
Thank you all in advance for your help!
Best Regards,
Yanick
02-Nov-2022 00:36
I found this :
it might help you.
02-Nov-2022 05:38
Hi mihaic,
Thank you for your answer. I tried to add this iRule, but it seems than SSL Forward Proxy needs a licence on the BigIP device, which I don't have:
Nov 2 08:34:44 f5-0905 crit tmm2[20835]: 01260000:2: Profile /INFRA-DEV/smtp-dev.domain.com_CS: Forward Proxy is enabled without a license.
For I think I will change my mind and let commuinication between F5 and the server unencrypted (SSL ofload).
Thank you very much for taking the time to answer me!
Regards,
Yanick
03-Nov-2022 08:58 - edited 03-Nov-2022 09:00
The iRule itself does not require forward proxy, I think that's a profile setting that is unnecessary with the irule (see below). Sam comments on this on the linked codeshare entry, if you still want to pursue the solution you're after.
Probably can disable these specific lines:
04-Nov-2022 05:46 - edited 04-Nov-2022 05:48
Hi JRahm,
On an F5 lab appliance we have deployed, we have all available licences, but it is limited to 10Mb/s.
I tried the iRule, but I was getting the same issue:
CONNECTED(00000003)
Compression: NONE
Expansion: NONE
No ALPN negotiated
SSL-Session:
Protocol : TLSv1.2
Cipher : 0000
Session-ID:
Session-ID-ctx:
Master-Key:
Key-Arg : None
PSK identity: None
Timeout : 300 (sec)
When using openssl (in STARTTLS mode), to test the connection, I will see on the /var/log/ltm, the "CLIENT_ACCEPTED" from the iRule debug line:
if { $DEBUG } { log local0. "CLIENT_ACCEPTED" }
Then it took maybe 10-15 seconds and the message "Didn't find STARTTLS in server response, trying anyway..." will appear.
I will now try your suggestion and disable ssl-proxy from the CS.
I'll keep you posted.
Thank you again for your reply.
Regards,
Yanick
04-Nov-2022 06:21 - edited 04-Nov-2022 06:23
Hi again!
I did the test, and I have the same result. Here is the config I have:
ltm profile client-ssl smtp-dev.domain.com-proxy-fwd_CS {
app-service none
cert-key-chain {
smtp-dev.domain_Sectigo_cert_chain_0 {
cert smtp-dev.domain.com_SECTIGO
key smtp-dev.domain.com_SECTIGO
defaults-from /Common/udes_clientssl_profile
inherit-ca-certkeychain true
ltm profile server-ssl smtp-dev.domain.com-proxy-fwd_SS {
allow-expired-crl enabled
app-service none
defaults-from /Common/udes_serverssl_profile
peer-cert-mode ignore
unknown-cert-status-response-control ignore
ltm virtual smtp-dev-25_vs {
creation-time 2022-11-02:10:30:50
destination 1.1.1.1%6:smtp
ip-protocol tcp
last-modified-time 2022-11-04:09:07:59
partition INFRA-DEV
pool smtp-dev-25_pool
profiles {
/Common/tcp { }
context clientside
context serverside
rules {
smtp-starttls_rule
source 0.0.0.0/0
vs-index 20
I'm using the iRules from the article postes by mihaic. Have the same behavior as described on my last post.
So, I think we will just use the F5 in passthru mode (no SSL) and install the certificate directly on the servers.
If someone has any suggestion I will be happy to test.
Thank you again for your help!
Yanick
