  • drteeth_127330's avatar
    drteeth_127330
    Historic F5 Account
    No, there isn't. But cookie persistence can be re-implemented fairly easily with the universal persistence rule commands. You could then insert a cookie with whatever attributes you want, encrypt it, etc. Why don't you take a stab at writing the rule and I'll help out if you have problems?
  • bl0ndie_127134's avatar
    bl0ndie_127134
    Historic F5 Account
    We have also provided a way to do an inplace AES encryption/decryption of the cookies. Here is an example.
          if {[HTTP::cookie exists "cookieName"]} {
            HTTP::cookie decrpt "cookieName" "passphrase"
      when HTTP_RESPONSE {
             HTTP::cookie encrypt "cookieName" "passphrase"
    Where the "passphrase" is a password based key. The encryption will effectively encrypt and base64 encode the cookie value for you.
