Slayer001's avatar
Slayer001
Icon for Cirrus rankCirrus
Sep 12, 2019
SAML SSO authentication via BIG-IP Edge Client for network access
We are trying to setup SAML authentication from one F5 APM as SP (network access VS) and another F5 APM serving as Idp.
The redirect towards the SAML logon page served by the F5 Idp is working. But when finishing the authentication steps on the Idp the policy flow of the access policy for the VPN starts again and the network access tunnel is not started.
According to the operations manual of BIG-IP Edge Client it should be possible to do SAML SSO in web logon mode. IS it then also possible to start the tunnel after successful SAML authentication?
We are running on version 13 of BIG-IP on both F5 APM's (the one running the network access VS and the one running the idp VS)
  • Hi,
    Did you check SP logs after SAML auth process in order to validate that authentication is well done...
    Can you confirm that you don't forget to assign a full webtop in your advanced ressour assign (with your NA).
    First of you have to target the problematic (VPN policy or saml protocol).
    we are in the same situation as you and it works correctly (NA + SAML Auth)
    regards
  • Yes we have assigned a full webtop in advanced resource assign.
    SAML response from the Idp is also success with the saml identity in the subject.
    After the SAML auth request we are redirected to the start of the VPN access policy which is a decision box. We use a decision box at the start as this is a lab setup used for multiple purposes. I'll try to setup without a decision box and see if that works better as I see this after the SAML auth request: xxx:8fa347d4: Executed agent 'xxx_act_saml_auth_ag', return value 3 ('Need User input'). Even before the SAML success reponse is received from the Idp
  • Forgot to mention that we are trying with the BIG-IP Edge Client
    Still same issue after removing the decision box. The policy of the VPN is restarted at the exact moment that the SAML response from the Idp is sent. The response redirects the user to /saml/sp/profile/post/acs Or should it be redirected to the webtop page?
    When I try the VPN in brower like firefox I'm successfully redirected in the browser to the full webtop where the network access is defined. Edge Client uses Webbrowser control and doesn't show the webtop (or only very briefly) but starts the VPN automatically after successful authentication normally. In the webbrowser control the SAML request and responses can't be checked like in a normal browser.
