Mike_Conant_598's avatar
Mike_Conant_598
Mar 07, 2005
Rules Problem
We just upgraded from 4.2 LB to 4.5.10 HA software on our Dell platform 2650 poweredge. We purchased this upgrade so that we could utilize rules based filtering of traffic based on a certain URI. We had an F5 partner perform the upgrade and write the rule. The rule does NOT work infact when we enable the rule on our box our site is unreachable. The F5 partner could not understand why this was happening. I placed a support call to F5 and open a case. The response from F5 was we dont help you with rules and that I would need to post my problem to DevCentral in hopes of someone here being able to help us. This is not at all what I expect for for support when I just paid close to 3K for one year of F5 support. Our rule is below has anyone had this problem before? I can be reached at mike@touchcominc.com we tried what F5 suggested below with no success.
You currently have this as a rule:
if (http_uri matches_regex "/onefacility/reporttest") {
use pool reporttesthttp
else {
use pool onefacilityhttp
Give this a try:
if (http_uri matches_regex "/onefacility/reporttest/") {
else {
Respectfully,
Steve
* Steve Pecsi | Network Support Engineer | www.f5.com
* P. 206 272 6888 | P. 1-888-88-BIGIP(24447)
* F5 Networks | 401 Elliott Avenue West | Seattle, Washington 98119
* The Leader in Application Traffic Management
* Ensuring secure and optimized application delivery for global enterprises
  • bknotwell_12713's avatar
    bknotwell_12713
    Historic F5 Account
    I'm not exactly sure why your rule isn't working (though I think you probably want to use the contains operator instead of matches_regex).
    I've appended some (sanitized) working 4.x rules that heavily use matches_regex:
      load balancing rules
     rule a {
        if (http_uri contains "/apack/") {
           use pool a
        else {
           if (http_uri contains ".cgi") {
              use pool acgi
           else {
              use pool ahtml      }
     rule b{
        if (http_uri contains "/bpack/") {
           use pool b
        else {
              use pool bcgi
           else {
              use pool bhtml
     rule c {
        if (http_uri matches_regex "\/~()(\/|$)") {
           use pool ccgi
        else {
           use pool cnormalcgi
     rule d {
           use pool dhtml
        else {
           use pool dcache
     rule e {
        if (http_uri matches_regex "\/~(frobnosticate)(\/|$)") {
           use pool ecgi
        else {
           use pool enormalcgi
     rule f {
        if (http_uri matches_regex "\/fpack\/") {
           use pool f
        else {
           if (http_uri matches_regex "\.cgi") {
              if (http_uri matches_regex "^\/~()(\/|$)") {
                 use pool fcgi
              else {
                 use pool fnormal
           else {
                 use pool fhtml
              else {
                 use pool fhtmlx
     rule g {
        if (http_uri matches_regex "\/~(cola|lemonlime)(\/|$)") {
           use pool g
        else {
           use pool gcgi
     rule h {
        if (http_uri matches_regex "^\/(~|%7E)(NON-STOP)(\/|$)") {
           use pool hhtml
        else {
           use pool hcache
     rule i {
        if (http_uri matches_regex "^/(/|(\./))*ipack/" or http_uri matches_regex "^/(/|(\./))*(~|%7E|%7e).*/ipack(.|..)(bbs|mail|all)/") {
           use pool i
        else {
           if (http_uri matches_regex "\.cgi($|\?|/|)") {
              use pool icgi
           else {
              use pool ihtml
  • I think your problem might be that in regex slash is a special char. You will need a backslash before each slash to treat it as a character.
    -Brian
