Technical Forum
Route traffic to VPN when split tunnel is enabled
cathy_123
Cirrus
Cirrus
hello everyone,
Question, I have a VPN and it has split tunnel enabled. If I want to use the VPN for a specific website example www.google.com how can I do this when the split tunnel is enabled? thank you
2 REPLIES 2
AlexBCT
MVP
MVP
Hi Cathy,
I think this is what you are looking for: https://support.f5.com/csp/article/K72735781
The DNS relay proxy service controls which DNS server is resolving the domain name. If you then ensure that your domain is resolved to an IP that is within the tunneled subnets, you should be good to go. If necessary, you could create an extra Virtual server on the F5 to route the traffic through for this particular domain name, and resolve the DNS entry to that Virtual server's IP.
Hope this helps.
cathy_123
Cirrus
Cirrus
thank you Alex will try this!
