Technical Forum
Rewrite URL iRule
darrenclegg
I have used redirect before and they have worked but can't get this rule to work.
When a user browses to abc.co.uk i want to change the URL in the browser bar to www.abc.co.uk. i have tried the following without success:
 if { [HTTP::host] equals "skipton.co.uk/" } {
 HTTP::header replace "Host" "https://www.skipton.co.uk/"
*with the / on the end
if { [HTTP::host] equals "skipton.co.uk"}
{ HTTP::header replace Host "www.skipton.co.uk"
*without the / on the end
if { [HTTP::host] equals "skipton.co.uk" } {
HTTP::redirect "https://www.skipton.co.uk[HTTP::uri]"
Can anyone see why it does not work and how to fix it? Much appreciated.
1 REPLY 1
Below iRule looks good, it should work.
if { [HTTP::host] equals "skipon.co.uk" } {
HTTP::redirect "https://www.skip.co.uk[HTTP::uri]"
Check under iRule statistics if you are seeing hits to it.
Mayur
