Muhannad's avatar
Muhannad
Icon for Cirrus rankCirrus
Oct 17, 2022
Solved
Rewrite Subdomain
Dears,
I am wondering about an efficient procedure to search and replace a specific Subdomain in the HOST, What i want to achieve is rewrite the HTTP request toward the server side as follows:
Client Request: DIRx.Clust1.Domain.com ----Should be forwarded to server side as follows:--- DIRx.Clust2.Domain.com, Only rewrite the Clust1 to Clust2 in the HOST, noting that the x value is variable DIRx and keep changing so i am unable to achieve the rewrite by simple Rule to replace the whole domain, i want to have a universal rule that can match the DIR# and copy it successfully to the domain when the rewrite happened.
Please can you guide me if there is any useful workaround.
Regards,
Muhannad
  • Code above is case sensitive on HTTP::host match.
    If you want a case-insensitive match you can run this instead
    #    log local0. "Client requested host: [HTTP::host]"
      if { [string tolower [HTTP::host]] starts_with "dir" && [string tolower [HTTP::host]] contains "clust1" }{
        HTTP::header replace Host [string map {"clust1" "clust2"}[string tolower [HTTP::host]]]
    #        log local0. "Modified host: [HTTP::host]"
    Oct 17 15:43:07 bigip info tmm7[11345]: Rule /Common/test-iRule <HTTP_REQUEST>: Client requested host: DIR000.Clust1.Domain.com
    Oct 17 15:43:07 bigip info tmm7[11345]: Rule /Common/test-iRule <HTTP_REQUEST>: Modified host: dir000.clust2.domain.com
  • when HTTP_REQUEST {
      if { [HTTP::host] starts_with "DIR" && [HTTP::host] contains "Clust1" }{
      HTTP::header replace Host [string map {"Clust1" "Clust2"}[HTTP::host]]
    Sample execution logs:
    Oct 17 15:32:37 bigip info tmm[11345]: Rule /Common/test-iRule <HTTP_REQUEST>: Client requested host: DIRx.Clust1.Domain.com
    Oct 17 15:32:37 bigip info tmm[11345]: Rule /Common/test-iRule <HTTP_REQUEST>: Modified host: DIRx.Clust2.Domain.com
    Oct 17 15:32:41 bigip info tmm6[11345]: Rule /Common/test-iRule <HTTP_REQUEST>: Client requested host: DIRy.Clust1.Domain.com
    Oct 17 15:32:41 bigip info tmm6[11345]: Rule /Common/test-iRule <HTTP_REQUEST>: Modified host: DIRy.Clust2.Domain.com
    Oct 17 15:32:43 bigip info tmm6[11345]: Rule /Common/test-iRule <HTTP_REQUEST>: Client requested host: DIRz.Clust1.Domain.com
    Oct 17 15:32:43 bigip info tmm6[11345]: Rule /Common/test-iRule <HTTP_REQUEST>: Modified host: DIRz.Clust2.Domain.com
    • CA_Valli's avatar
      CA_Valli
      Icon for MVP rankMVP
