Anoop_Dharan_20's avatar
Anoop_Dharan_20
Jun 24, 2018
Remove a node from LC
Hello Folks,
How would i remove an old ISP which eventually processing any traffic(as per service provider update) from my LC. This ISP has been member of many pools and all of them are defied in an iRule as well. Should i disable one by one pool member and later remove them from the pool and then from node level.
  • Hi Anoop.
    • First of remove/delete the node from all your Pool (node will be the GW of your old ISP).
    • then from your Wide IP remove all the VS that used old ISP Lan.
    • Then remove this VS.
    • Finaly in your node remove the GW of the old ISP.
    Regards
