Peter_Bevington's avatar
Peter_Bevington
Feb 14, 2012
Redirection
Not been iRuling for very long
I have a requirement to redirect traffic from to
I don't want to use HTTP::redirect as this will create more traffic and would like to redirect to a pool
I'm doing the following but am finding that the "new-pool' isn't being used
switch -glob [string tolower [HTTP::host]] {
"server1*" {
HTTP::header replace Host $spr_site
switch -glob [string tolower [HTTP::uri]] {
HTTP::uri "NEW-URI"
pool "New-Pool"
Anyone have any help or advice ?
  • hoolio's avatar
    hoolio
    Hi Peter,
    Can you add logging to the switch statements to see whether the pool command is being reached?
    http://devcentral.f5.com/wiki/iRules.log.ashx
    Aaron
