William_Them_99's avatar
William_Them_99
Jun 15, 2005
Redirect after when AUTH_FAILURE
We have iRules to handle authentication of client cert attributes against an LDAP tree. Right now, when the user fails to authenticate with LDAP, the code does this:
when AUTH_FAILURE
if {$tmm_auth_ssl_cc_ldap_sid eq [AUTH::last_event_session_id]}
reject
This results in a default "This Page Cannot Be Displayed" error in Internet Explorer. We would rather have the user be redirected to a page that can inform them of why they cannot access the requested resource.
Since I can't place the HTTP::uri "mypage.html" within the when AUTH_FAILURE statement, how can this be accomplished?
Thanks for the help.
  • This is our Auth rule:
     when CLIENTSSL_CLIENTCERT
       set issuer [X509::issuer [SSL::cert 0]]
       if {$issuer contains "Verisign"}
         log local0. "Issuer is $issuer"
         log local0. "Setting to profile test_ldap Verisign"
         set myprofilename "test_ldap_profile"
         set tmm_auth_ssl_cc_ldap_sid [AUTH::start pam $myprofilename]
         AUTH::cert_credential $tmm_auth_ssl_cc_ldap_sid [SSL::cert 0]
         AUTH::authenticate $tmm_auth_ssl_cc_ldap_sid
         SSL::handshake hold
     when AUTH_SUCCESS
       log local0. "auth_success"
         SSL::handshake resume
     when AUTH_FAILURE
         reject
     when AUTH_WANTCREDENTIAL
         reject
     when AUTH_ERROR
         reject
    With more logging, I found that when a user comes in with a client certificate that is not in the LDAP, none of the AUTH_FAILURE, AUTH_WANTCREDENTIAL, or AUTH_ERROR events seem to be firing...I didn't see any of my log statements in /var/log/ltm other than the default pam_authenticate: 6 AUTH: Permission denied messages.
    So maybe I need to put this HTTP::respond thing somewhere else?
  • unRuleY_95363's avatar
    unRuleY_95363
    Historic F5 Account
    Perhaps you want to add it as an "else" clause after the "if { $issuer contains "Verisign" } {...}"?
  • I have picked up where Bill left off and still cannot get this to work.
    The AUTH_FAILURE does fire (I'm not sure if it is because I turned on mod SSL) but when I tried adding the http respond to the AUTH_FAILURE event I get an "operation not supported" in the log. HTTP::redirect and HTTP::uri will not even get saved after updating the iRules. I have also tried setting flags as seen in numerous other appends, but the setting does not get carried outside the AUTH event. I can see the variable get set in the AUTH, but by the time the next even hits, the value is not what it was set to inside the AUTH event (for both successes or failures). I have queried the value in numerous events but it never is the one set in the AUTH event. I was going to try AUTH::status but did not know how to get the authid. When I tried adding AUTH::last_event_session_id inside the HTTP_REQUEST I received an error in the log.) This is the current irule on the server (we have CLIENTSSL_CLIENTCERT events in the AUTH profiles).
    when AUTH_SUCCESS
    set auth_code 0
    when AUTH_FAILURE
    log local0. "auth_failure"
    set auth_code 1
    log local0. "auth_failure - reject, auth_code is $auth_code"
    reject
    HTTP::respond 303 content http://myhost /Errors/AuthenticationFailed.html
    log local0. "auth_wantcredential"
    reject
    when AUTH_ERROR
    log local0. "auth_error"
    reject
    log local0. "in http request, auth_code is $auth_code"
    if {$auth_code eq 1} {
    log local0. "Found Error in http request"
    HTTP::redirect http://myhost/Errors/AuthenticationFailed.html
  • Tao_Liu_90341's avatar
    Tao_Liu_90341
    Historic F5 Account
    That is because client cert auth happened before HTTP was active. You may have to postpone auth, try to replace CLIENTSSL_CLIENTCERT with HTTP_REQUEST if this delay is acceptable.
    Also replace "SSL::handshake hold" with HTTP::collect, replace "SSL::handshake resume" with HTTP::release
