Sort By
- Josh_41258NimbostratusIn the past when I have had to do this, I ended up manually modifying bigip.conf and moving the specific configuration into the new partition. I'm not sure there is a way to handle this via the UI. I wish there was, though.
- HamishCirrocumulusThere is no way from the GUI or the ClI to move between partitions... You have to create them there..
- Daniel_21056NimbostratusI am not finding a way to create a VIP in a different partition either. Is there an option I am missing somewhere when creating the VIP?
- hooleylistCirrostratusHi Daniel,
