Technical Forum
Pulse Connect Secure behind ASM
NayanTrivedi
Need help as we are planning to have Pulse Connect Secure behind F5 ASM. As the Pulse Secure Connect requires tcp/443 and udp/4500, will that works with ASM?
5 REPLIES 5
boneyard
MVP
MVP
in principle it should work, just remind that you should only enable ASM on the TCP/443 (HTTP) traffic. the UDP/4500 traffic just hits a virtual server and is forward to the pool without ASM inspection as that can't be inspected.
@NayanTrivedi  Curious to hear whether this was successful or not.
yeah same, any word @NayanTrivedi ?
Thank you guys for help. We postponed moving pulse behind ASM currently.
Leslie_Hubertus
Community Manager
Community Manager
Totally off-topic, but I've been going through all the posts on the site, and love seeing how active @JoshBecigneul  and @boneyard  have been/are being. You guys make a huge positive difference in the community, and I'm sorry I don't feature you in every week's Highlights article (since I want to give other community members a chance to shine there as well).
All that to say, thanks for doing what you do and being so helpful.
